View Full Version : Jamming bizhub362 adf wont pull
garrycmsi
02-01-2018, 05:14 PM
I have a bizhub362/df620 that does not pull from document tray reliably. I have cleaned and lubed feed clutches,cleaned rollers still will not always pull.
any ideas?
Thank You
Albonline
02-01-2018, 07:56 PM
any ideas?
Thank You
replace the one ways.
copier addict
02-01-2018, 08:10 PM
any ideas?
Thank You
In the main drive there is a one-way gear that starts to slip. I have sometimes been lucky enough to just get some alcohol on it and have it work. Otherwise you will need to get that gear off and clean it. Also clean and scuff the shaft it runs on.
You need to take the rear cover off to get at this one-way gear.
Albonline
02-01-2018, 08:14 PM
with the work involved just replace it.
