View Full Version : Di5510 j17-10
konisolver
09-12-2008, 03:12 AM
I have a J17-10 that as soon as I turn the copier on the jam code appears. There is no paper anywhere (adu/conveyance/exit) In service mode 47 code 23-3 (PS44 shows a constant H) I swap the upper and lower photosensors with the same result. I also replaced the ADU driver board - any suggestions?
Scott_Lewis
09-12-2008, 07:24 AM
Have you checked for continuity from the sensor connector to the ADU board?
konisolver
09-12-2008, 11:52 PM
Short on the wire.
DUKEY
09-13-2008, 04:02 PM
this machine dumps toner and developer!!! not all but alot of them.. u must take adu apart and clean the sensors which are giving u the high, i've never seen a short or pinched wire before, but there is always a first!! was the machines adu serviced while on? make sure dip sw 3-1 not on! its the latch for lock ups
