View Full Version : Miscellaneous Konica Minolta c253 weird sound and waste toner Box is full
mearmi
02-05-2018, 07:39 AM
Konica C253
Last week replaced Black (Katun) Toner.
Today started getting weird sound and copier says waste toner box is full.
vaccumed hopper unit Black and it works for 100-150 copies and again same problem.
please advise
joelea
02-05-2018, 10:26 AM
Konica C253
please advise
have you also cleaned the window on the waste toner unit? It may be dirty and triggering the waste toner full. I pop them off with a stanley blade and then glue back with a bit of uhu glue.
joelea
02-05-2018, 10:27 AM
Konica C253
please advise
Also the noise could be the transfer belt cleaning unit clogging up, I would be taking the belt out and hoovering the belt cleaning unit out.
mearmi
02-05-2018, 11:40 AM
Thanks for your reply.
u mean Waster Toner Box?
joelea
02-05-2018, 12:29 PM
Yeah 😉
insigniawales
02-05-2018, 07:16 PM
Good Luck with this. Can be a tricky problem to resolve. Check waste toner and transfer belt.
Sent from my SM-G903F using Tapatalk
tech51
02-05-2018, 07:26 PM
Chances are the waste pipe that links the image units at the rear are blocked up and making the drive jump to the waste bottle, giving you the message.
The pipes have to removed and cleaned out which is a major job.
There are posts on this forum somewhere covering this but believe me when I say it's a very long job.
copier tech
02-05-2018, 08:36 PM
We write off machines when they had this issue simply not worth the time to repair.
rrrohan
02-06-2018, 05:54 AM
using non genuine toner prob contributed
copier tech
02-06-2018, 07:18 AM
Yes, or we found in low usage or hot or damp environments caused this issue.
vedder
02-06-2018, 09:22 AM
We have condemned more than 1 machine due to this problem, as mentioned above, it`s a stinker of a job getting to where you need to get to, the whole machine needs ripping apart, ripping it apart is the easy bit, getting it all back together again can be problematic ;-)
vedder
02-06-2018, 09:24 AM
Konica c203 noise! (http://www.copytechnet.com/forums/konica-minolta/92023-konica-c203-noise.html)
insigniawales
02-06-2018, 09:42 AM
Has anyone had any success with compatible toners?
AjitN
02-06-2018, 01:39 PM
To cut short in simple words,
IT IS NOT WORTH TO DO ALL THIS JUST FOR WE/ CUST WANTS TO GET ON WORKING.
In next few days it will need some
