View Full Version : C451 w/ problem of c3423
verchez
09-14-2008, 07:19 AM
I have c451 with error code c3423 which means problem in heater unit pressurizing side. I am able to reset it but after a week it happened again.
What i can i do to finally solve it?
RockETop
09-14-2008, 04:21 PM
How many copies?
Likely, a new fuser....
verchez
09-15-2008, 05:32 AM
The machine is just a week old from installation when the first code c3423 appeared. Anyhow i will try to swap the fusing unit to other c451 machine just to try.
Albonline
09-15-2008, 05:00 PM
is supply voltage correct? (wall outlet)
verchez
09-17-2008, 05:35 AM
Yap the machine is 110 volts connected to a voltage stabilizer.
bigmark
09-18-2008, 02:40 AM
another thing to check, along the lines of the wall outlet - is the outlet a dedicated 20amp outlet. many people are just placing 20 plugs on a 15amp circuit, or using a pig tail to connect to wall.
