View Full Version : Miscellaneous skewd copy bizhub 600
Gulbadin
02-18-2018, 01:04 PM
38903
when i copy on A6 paper the result is crooked skew on bizhub 600.on A4 paper the copy is fine
blackcat4866
02-18-2018, 03:13 PM
Are you feeding A6 (International Postcard: 105 x 148mm/4.13 x 5.83 inches) paper from the bypass? That is the only tray capable of handling paper that small. And it must be fed SEF (105mm at the leading edge). The smallest paper that can be fed from the paper trays is A5 SEF (148 x 210mm/5.83 x 8.27). =^..^=
Gulbadin
02-19-2018, 06:15 AM
yes the paper is fed from bypass tray
blackcat4866
02-20-2018, 12:38 AM
SEF? It doesn't look like it. =^..^=
