View Full Version : 754e 9401
M3HR4N
02-21-2018, 03:00 PM
Hey fellas, I want to firmware bizhub 754e, in the menu there is an option named Machine Type what hex should i enter in the field?
The firmware version is A55V0Y0-F000-G20-M0 and when the process complete the machine comes up the code C-9401
any help would be appreciated and Thanks in advance :)
habik
02-21-2018, 03:14 PM
any help would be appreciated and Thanks in advance :)What does the service manual says about that code?
Sent from portable device using fast cheapset!
Synthohol
02-21-2018, 03:21 PM
Machine type has absolutely nothing to do with upgrading firmware machine type is only to be used when particular boards are changed and the boards have no idea of their country of destination I would just leave it alone
Albonline
02-21-2018, 06:11 PM
Trouble type Exposure LED lighting failure
Trouble code C9401
Rank A
Detection timing • The output from the CCD sensor is a predetermined value or less during CCD sensor gain adjustment.
• The wrong model of firmware is detected in the MFP board when the main power switch is turned ON.
• The machine type information (Machine, Type) registered to the machine differs from the actual machine
did you change boards around? is the firmware you are using correct for your model?
Albonline
02-21-2018, 06:15 PM
First four digits of the
serial number
A55V= 20 a5yn=21
