View Full Version : Dead Machine Konica Minolta C454 replenish magenta toner issue
G6token
02-25-2018, 06:03 AM
I have a client that has a C454 color copier, they first called me about the a code that appeared. 255x pertaining to the developing unit. I replaced it from a working C454 that I had. Now the code was gone, but a new issue occurred. Replenish magenta toner, I popped a brand new canister in there and same thing. I figure maybe some sensor to do with the toner hopper. I removed it pulled it apart completely and cleaned it like brand new. Placed it back in the copier samething. Frustrated at this point I removed a working hopper unit from one of my copiers cleaned it and installed it into this clients machine. Hard reset and power back on. The machine comes up without a hitch. I say now maybe the hopper unit was faulty and caused the flow of toner to the dv to be interrupted. 1 month later I’m called back. Replenish toner. maagenta toner:mad:. The client stated that he ran his previous magenta toner right down to it was finish and then replenish toner popped up. New canister installed same thing. Hard rest same thing. I came removed the hopper unit cleaned it, renosntalled it. No difference. I removed the magenta dv it seemed low so I topped it up with some from a c452 Magenta unit. Poured enough till the level seemed okay when roatating popped it back in. Hard reset. Samething. I’m lost at this point. The only thing I’m thinking is, the toner isn’t OEM so either it not keeping the dv unit topped up causing it hard to rotate, or it clogging the toner hopper maybe causing the motor to operate abnormal or fail disrupting the flow of toner. ??? Please help or atleast a push in some sort of direction.
rrrohan
02-25-2018, 06:31 AM
wouldnt just manually filling the dev like that upset the TCR level even more?
G6token
02-25-2018, 07:15 AM
Not quite sure. I haven’t heard that one. I was thinking to just change replace the Dv unit again.
rrrohan
02-25-2018, 09:30 AM
if you do that i do drum at same time. if the drum is pulling dev you may end up ruining the new dev as well
Synthohol
02-25-2018, 03:15 PM
you already answered yourself.
dont skimp on the toner, thats buying a shovel to dig your own grave.
blackcat4866
02-25-2018, 03:55 PM
I can't think of anything to add to that. =^..^=
G6token
02-25-2018, 06:25 PM
What do you think is a definite resolution?
blackcat4866
02-25-2018, 07:05 PM
I think that I wouldn't have done any of the things that you did. Based on everything that I've read so far in this thread, I want nothing to do with it. =^..^=
I have a client that has a C454 color copier, they first called me about the a code that appeared. 255x pertaining to the developing unit. I replaced it from a working C454 that I had. Now the code was gone, but a new issue occurred. Replenish magenta toner, I popped a brand new canister in there and same thing. I figure maybe some sensor to do with the toner hopper. I removed it pulled it apart completely and cleaned it like brand new. Placed it back in the copier samething. Frustrated at this point I removed a working hopper unit from one of my copiers cleaned it and installed it into this clients machine. Hard reset and power back on. The machine comes up without a hitch. I say now maybe the hopper unit was faulty and caused the flow of toner to the dv to be interrupted. 1 month later I’m called back. Replenish toner. maagenta toner:mad:. The client stated that he ran his previous magenta toner right down to it was finish and then replenish toner popped up. New canister installed same thing. Hard rest same thing. I came removed the hopper unit cleaned it, renosntalled it. No difference. I removed the magenta dv it seemed low so I topped it up with some from a c452 Magenta unit. Poured enough till the level seemed okay when roatating popped it back in. Hard reset. Samething. I’m lost at this point. The only thing I’m thinking is, the toner isn’t OEM so either it not keeping the dv unit topped up causing it hard to rotate, or it clogging the toner hopper maybe causing the motor to operate abnormal or fail disrupting the flow of toner. ??? Please help or atleast a push in some sort of direction.I would have put OEM toner in it when I changed out the developer. Why make things harder on yourself. Also as stated replace the drum for good measure. Not all toner is made equally you're just asking for trouble using compatible. You may get away with compatible 9 out of 10 times but it only takes one bad one to drive you crazy!!!
Sent from my SM-G955U using Tapatalk
Synaux
02-25-2018, 10:00 PM
First, you probably should NOT have even mentioned the toner is not OEM some of these guys are probably in the process of tracking you down to beat you with an ugly stick right now :rolleyes::p
Anyways, is the hopper full of toner or actually getting low?
I dont know if this is an issue with this model, but on some, the warning will not go away until that stupid shake the canister message appears and the TCR articles is then reset.
What is the TCR level reading in SM?
Is the image quality even affected?
copyman
02-25-2018, 11:14 PM
At this point I would change the developer unit, drum & toner *ALL NEW OEM. It has to be a new DV unit to reset the voltages, etc.
Keep in mind "any" over life Trans belt, drum or dv unit can cause "any" color dv unit to take a dump!
Woxner
02-25-2018, 11:15 PM
its never a good idea to swap dev from one machine to another. the age and calibration wiil be different. in history toner shoukld be 6.6 or 6.2 % ROUGHLY you maybe pulling dev. i think there is bullitens on this.
