View Full Version : Bizhub C253
twinax
09-16-2008, 10:55 AM
Hello
I have an error T73 when i send and receive a fax.
On the technical service manuel of FK 502
CODE N°T73 Category:Transmision Contents of Error:Modem response waiting T.O (60 seconds) .
We changed the PBA fax and the MPFP.(idem)
The Fax has worked during one year,we tested the line with another fax .
That's correct.
You have an idea .
Oliver
bludlow
09-26-2008, 06:59 PM
Go into fax in tech rep mode and under the comm, other Tab turn the ECM off.
I have found that any companys that have any kinda of dig phone line have to have this ECM turned to the off pos.
E Winter
09-26-2008, 07:21 PM
First you should check the line for noticeable backgroind noises.
Disable V8/34 protocols and JBIG compression, lower the max. tx/rx speeds to 14.4 and if this does not help: deactivate ECM
bigmark
09-27-2008, 01:43 AM
also make sure its not a VOIP line. Konica does not support VOIP lines on the fax kits at all. There are converters that might work... but the only ones that I have seen work are by cisco, and very pricey. also, make sure the firmware level on the fax kit is at 7
it may still be at 6
