View Full Version : Looking for reliable c220 and c224e series dev & drum reset device
Don N.
02-28-2018, 11:13 PM
Anyone tried the reset switch/harness/device found on e-bay or elsewhere? We refurb & sell these machines so I don't just want to use life optimization or dip sw settings. I want to replace developer after it goes bad with aftermarket dv which has been working well so far, but we use too many reset chips. We also use new drums, blades & chargers to r/b the drum units, and they work good as OEM. Again, just burning through too many chips.
I've googled & searched but not finding any strong tech endorsement of these devices. There's a pic of one from ktn with a part #, but I guess they disc. the item bc the ktn part# comes up invalid.
Really would like to find one that does c220 & c224e series, drum & dev.
Thanks!
rrrohan
03-01-2018, 02:16 PM
Why not just disable consumable life reminder and set the to no stop.
Don N.
03-01-2018, 02:54 PM
When new developer is installed (aftermarket, with old dv unit) it needs to be calibrated and reset. Same with rebuilt drums. We aren't just ignoring or resetting units that are past life.
myster
03-01-2018, 05:35 PM
If you can
We have one device built by us to reset drums and developers.
jabatt
03-08-2018, 05:09 PM
Thanks!
I'm a Korean.
I am making and selling.
This is Pusan in Korea.
It can be purchased through importers.
Company Name: Daewoo OA System
*konicaminolta bizhub C220/C280/C360 series dev & drum reseter
39092
*konicaminolta bizhub C224/C284/C364/C224e/C284e/C364e series dev & drum reseter
39093
Don N.
03-09-2018, 01:34 PM
I'm a Korean.
39092
39093
PLEASE direct me to the vendor. I want to try it.
Zoran
06-18-2023, 12:36 PM
I think my project is better than others
58628
https://youtu.be/65i_GagUqo8
M RESET C224
This unique M RESET C224 Device enables Technicians to reset Developer Units without changing existing TCR sensors. This device has unlimited number resets and can be used as an onsite tool or in a workshop based .
Using:
1.
After installing compatible developers ,in the developer image unit, it is necessary to perform a reset of the developer image unit in order for the TCR sensor to remember the concentration of the toner the value triggers the toner supply.
2.
In the case of errors related to the concentration of toner - developer unit (C2551, C2553, C2555, C2557, C2411, C2412, C2413, C2414, C2552, C2554, C2556, C2558, C2559, C255A, C255B, C255C, C2561, C2562, C2563, C2564. .) and after the repair it is necessary to reset the TCR sensor.(If necessary, reduce or increase the concentration of toner in the developer from the service mode)
Compatible with:
bizhub C220/bizhub C280/bizhub C360/d-Color MF220/d-Color MF280/d-Color MF360/ineo+ 220/ineo+ 280/ineo+ 360
bizhub C224/bizhub C284/bizhub C364/ineo+ 224/ineo+ 284/ineo+ 364
bizhub C224e/bizhub C284e/bizhub C364e/d-Color MF222 plus/d-Color MF282 plus/d-Color MF362 plus/ineo+ 224e/ineo+ 284e/ineo+ 364e
bizhub C454/bizhub C554/bizhub C454e/bizhub C554e/d-Color MF452 plus/d-Color MF552 plus/ineo+ 454/ineo+ 554/ineo+ 454e/ineo+ 554e
bizhub C227/bizhub C287/bizhub 367/CM2041/CM2101/D300/D301/D310/D311/ineo+ 227/ineo+ 287/ineo+ 367/d-Color MF 223/d-Color MF283
bizhub C258/bizhub C308/bizhub C368/bizhub C458/bizhub C558/bizhub C658 /d-Color MF254/d-Color MF304/d-Color MF364/d-Color MF454/d-Color MF554/d-Color MF654/MFX-C2590/MFX-C3090/MFX-C3690/MFX-C4590/MFX-C5590 /ineo+ 258/ineo+ 308/ineo+ 368/ineo+ 458/ineo+ 558/ineo+ 658
bizhub C250i/ bizhub C300i/ bizhub C360i/ineo+ 250i/ineo+ 300i/ineo+ 360i
bizhub C221/bizhub C221s/bizhub C281/ineo+ 221/ineo+ 221s/ineo+ 281
bizhub C3350i /bizhub C4050i /ineo+ 3350i /ineo+ 4050i
bizhub C3350/bizhub C3850/ bizhub C3850FS/d-Color MF3300/d-Color MF3800
bizhub C4000i/ bizhub C3300i /ineo+ 4000i/ineo+ 3300i
bizhub C3851/ bizhub C3851FS
bizhub 224e/bizhub 284e/bizhub 364e/ ineo 224e/ineo 284e/ineo 364e
bizhub 454e/bizhub 554e/ ineo 454e/ineo 554e
bizhub 654e/bizhub 754e/ ineo 654e/ineo 754e
bizhub 227/bizhub 287/bizhub 367/ ineo 227/ineo 287/ineo 367
bizhub 308e/ bizhub 368e/ bizhub 458e/ bizhub 558e/ bizhub 658e
bizhub 308/ bizhub 368/ bizhub 458/ bizhub 558
With this tool you will no longer have to spend money buying chip because the tool allows you to reset as many times as you want and allows the use in other equipment infinitely resets the image Drum unit .
The device reset drum unit allows the reset of the drum unit with a in numerous equipment of the , ie a single device can reset the drum unit more than a 72 million times and of without the need for a chip or an exchange of the chips.
Using:
1
After replacing a compatible OPC drum.
2
Device also allows the use of black image Drum unit in place of the color image Drum unit .
In addition to resetting the drum units the reset when permanently connected to the equipment allows the use of the drum unit K (Black) instead of the Drum unit color, ie you can buy to put in the equipment only Drum unit k (black) instead of the drum unit color thus having a huge economy since the Drum unit K (black) is much cheaper than the drum unit color.
M RESET C224 allows to select an opc drum for reset using the switch.
The micriswitch ON position allows resetting.
In the position of the OF device, it can permanently remain in the device and replaces the chips of all drum units.
(in the bizhub C220 series .. it can replace black and one color)
M RESET can also reset toner status chips for C554e, C308...
M RESET C224 has a light indication of a successful reset.
lomenadam
10-12-2023, 12:07 PM
But how is this actually work? Just some buttons and the cable or any electronics in there?
I'd like to build one instead of buying it.
58628
M RESET C224
Using:
1.
2.
Compatible with:
Using:
1
2
I started to reverse engineer the chip function some time ago, it's a simple circuit of (iirc) two resistors and a fuse wich blows during initialization leading to different "before+after" ohm values. So you basicly can recreate this with a little knowledge. I never finished that because we get the drum chips cheap as fuck and convert BK DV units for COL wich doesn't require the more expensive DV chips anymore.
I don't know the price of Zorans device but if it's targeted around 100€ I think it's not worth the time to built your own resetter unless you find it entertaining beeing McGyver (wich I find amusing sometimes).
Hansoon
10-13-2023, 05:57 AM
We get very good working drum and developer unit chips for all KonicaMinolta and Lexmark machines, so no need to fiddle around in front of the customer with any obscure looking tool.
Hans
CP-1015
10-13-2023, 07:26 AM
Is it allowed to introduce my Resetter here? The other two has "red cards".
tsbservice
10-13-2023, 08:00 AM
Better leave it for PMs from interested in...
CP-1015
10-13-2023, 08:06 AM
Thanks, it's difficult because the chances are greater in the forum, but I'll stick to the rules.
Hans
:D:D:D #notasuicidebomber
CP-1015
10-13-2023, 08:24 AM
Thanks!
Your PM box is full ;)
copyman
10-13-2023, 01:08 PM
It's ok to introduce your Resetter on the forum. No rules or policy followed here. Not even sure if there is an admin anymore on this website. I tried emailing the admin several times in the past and never a response. If political fighting and other crap is allowed then a long time member like yourself introducing the resetter should not be a problem. Go for it!
CP-1015
10-14-2023, 08:07 AM
Now, I think, the same rights for all, include me.
Drum and developer resetter for A4 and A3 devices:
for all common Konica Minolta machines and identical in construction (Develop, OCE, Olivetti, Kyocera, Triumph Adler…)!
7 pieces with illustrated operating instructions in a practical case!
Sales only to specialist retailers!
Never buy chips again - just reset units after overhaul.
• Save money because there is no storage of chips
• Time savings because no assembly is required
• environmentally friendly with no waste because it can be reused endlessly
• Individually for black, cyan, magenta and yellow
• Separately for drums, developer units or imaging unit
• intuitive operation
Scope of delivery:
1. Developer and imaging unit resetter new, switchable for C-3300i series
2. Drum resetter
3. Drum resetter for C-250i/300i/360i/450i/550i/650i series
4. Adapter black drum resetter for C-227 and C-227i series
5. Adapter monochrome devices
6. Operating instructions as a PDF file via email
7. practical emergency case
Optional: Drum Adapter C-220 series
Compatibility and practical case with unlabeled resetters:
Hansoon
10-14-2023, 10:49 AM
I buy drum chips for less than a Euro and developing units for Euro 2.50. So no need to twiddle on site with reset equipment. I do not like to explain to a customer breathing in my neck what I am doing with his new installed parts. Internet informs them very well nowadays.
All units, drums as well as developing units leaving our shop are rebuilt and the necessary chips are already installed from the beginning. On site, we never reset anything.
Hans
copyman
10-14-2023, 12:59 PM
Hans
I do the same as Hans. All units rebuilt in shop with new chips. Plus no chance of shorting out machine with connecting wires, etc.
The resetter was good years ago when chips weren't available or inconsistent.
CP-1015
10-23-2023, 03:35 PM
Sorry, forget:
Don N.
10-23-2023, 03:51 PM
""Your PM box is full ;)""
My box has been full for years. Never used it once. Can't reset it. I too emailed the webmaster a few times. Like Copyman says, this site may not have a webmaster. If anyone knows otherwise, please redirect this longtime issue as you see appropriate.
CP-1015
10-24-2023, 08:19 AM
Now I wrote it here: #17
Zoran
10-25-2023, 06:43 AM
My reseter also works on other devices
You can see the resetter tests and working procedure at Zoran Petkovic - YouTube (https://www.youtube.com/channel/UC3N9Yo2USFqWWokDjZO1ZqQ)
THERE IS A RESET POSSIBILITY. In the phase of testing on models
OKI C330DN OKI C530DN OKI MC361 OKI MC561 OKI MC890 OKI MC950 OKI B401d OKI B401dn OKI B431dn OKI B432d OKI B432dn OKIC330dn OKI ES5112 OKI MB451 OKI MB411 OKI MB431 OKI MB461 OKI MB481 OKI MB491 OKI MB461 OKi MC360 OKI MC362 OKI MC562 OKI C5200 OKI C5200 OKI C5200N OKI C5200DN OKI C5150 OKI C5300 OKI 5300N OKI C5400 OKI C5400N OKI C5400TN OKI C5400DTN OKI C5500n OKI C5500 OKI C5510 OKI C5540 OKI C5550 OKI C5550n OKI C5600 OKI C5650DN OKI C5700 OKI C5800 OKI C5800Ldn OKI C5850 OKI C5900 OKI C6150DN OKI C6150DTN OKI C821 OKI C830OKI OKI MC860 OKI C8600 OKI C8800 OKI 7350 OKI C7350 OKI C7350N OKI C5950 OKI MC560 OKI C610 OKI C710 OKI C711 OKI C801 OKI C810 OKI C9600 OKI 9650 OKI 9800 OKI 9850
Xerox Imaging Drum Reset 108R00647, 108R00648, 108R00649, and 108R00650, Xerox 7400 Phaser fuser , Reset Imaging Drum Fuse for Xerox Phaser 7400, 7400DN, 7400DT 7400DX Xerox P8E 113R296 100R364 WorkCentre 385 Toner Cartridge Xerox Work Centre 7228 7235 7245 7328 7335 7345 7346
Samsung Xpress SL C410W SL C460FW C460W Abps CLP 310 315 320 325 CLX 3170 3175 CLP 409 CLRT 409 Imaging Drum SCX 6320R2 Drum SCX 6320 SCX 6322DN SCX 6520FN CLX 3185 CLX 3185N CLX 3185 FN FW ml 1750 Toner Cartridge SCX 4216 and SF 550 CLP 325 CLX 3180 CLX 3185 CLP3180 CLP 360 365W 368 CLX 3305FW 3300 CLP365 CLP365W CLP365EXP CLP360
Ricoh Aficio MP C3002 C3502 C4502 C5502 MPC3002 MPC3502 MPC4502 MPC5502 MP-D400 D401 D410 D411 D412 MPC3003 MPC3503 MPC4503 MPC2503 MP 2554 3054 3554 4054 5054 6054 MP4054 MP2554 2555 3055 3555 4055 5055 6055
Xante Ilumina Drum Reset Chip 407 502 Oce cm 4525 6520 CS 173 180 193 230 CM2520 CM3521 CM3525 CM4521 Lexmark Optra E310 312 13T0101 12A2202 HP CLJ 4700 CP 4005
