View Full Version : Miscellaneous CE PASSWORD
ranjitkr16
03-01-2018, 06:34 AM
Hello guys , any body had idea about to reset CE password in Bizhub 501 as its not open with 92729272.
Woxner
03-01-2018, 03:22 PM
did you try the code were its 9272 4 times instead of two.
ranjitkr16
03-05-2018, 04:44 AM
There is not that much space to type 4 times bro
vishop
03-05-2018, 08:49 AM
try this: 07412369
ranjitkr16
03-05-2018, 11:31 AM
try this: 07412369
No bro...it also didn't work...password failure
Synthohol
03-05-2018, 11:59 AM
all zeros? blank? 12345678?
ranjitkr16
03-06-2018, 05:17 AM
Tried...not working...shows password failure 😓
Synthohol
03-06-2018, 01:07 PM
How to access Service Mode when unable to use the normal procedure.
Answer
Service Mode can be accessed through the Trouble Reset screen using the below procedure: 1. Turn ON the main power switch while holding the UTILITY/COUNTER key.
2. When TROUBLE RESET appears on the touchscreen press STOP, 0, 0, STOP, 0, 1.
3. If prompted for a password enter 92729272 and touch END.
see if that works.
good luck
