View Full Version : Electrical Fitting a C454e fuser to a C224e model
copier tech
03-03-2018, 11:30 AM
Quick question, is this possible? different part numbers for both fusers but they look the same!? :confused:
Synthohol
03-03-2018, 01:15 PM
i remember the 3 series you could put a faster fuser in a slower model, the heat lamps were a higher wattage, you just couldnt do the reverse because it couldnt keep up.
the 4 series has no lamps so trial and error? are they geared exactly the same? i never took notice.
copier tech
03-03-2018, 01:30 PM
The 4 series DOES have a lamps, a pair of them.
Synthohol
03-03-2018, 03:52 PM
honestly i never took one apart, i thought the whole induction thing did it all.
my bad.
copier tech
03-03-2018, 05:15 PM
I only found this out because I had dead new unit, turns out lamps were broken so fitted another lamp from an old unit!
