View Full Version : Konica Minolta C2452 code
JVC
03-09-2018, 09:54 PM
Hello
I am a Toshiba tech working on a Konica Minolta Bizhub Press C6000L. It came in with a C2451 code. To check if it was in the yellow developer I switched the units around covering the inlets with no change in code. The machine came in with no magenta toner so when the toner came I tried adding a little toner directly into the unit and ended up with a C2452 code then a C2453 code and back to the C2452 code. I would greatly appreciate any suggestions.
Thank you in advance for any and all help.
stuckmx
03-09-2018, 11:21 PM
Hello
SENT U A PM
