View Full Version : Bizhub 200 Printing w/ SCO Openserver 5
DocuSystems
09-17-2008, 08:21 PM
Anyone have any advice on setting up network printing to a Bizhub 200 from SCO Openserver 5? Need to be able to setup tray options & duplexing for invoice and statement printing. Customer's network has a router setup with the Bizhub connected using DHCP/Hostnaming.
Trying to get some idea of what to expect before I make the trip.
scarmardo
11-24-2008, 07:02 PM
I'm also trying to figure out how to specify tray options in SCO OpenServer 5.
Did you learn anything about getting your bizhub to work?
Thanks,
William
DocuSystems
12-01-2008, 08:10 PM
Yes, it works. You can use the KM Print Utility which corresponds to the version server you are using. Downloadable from KM's website. Also you'll need the PPD for the Bizhub 200, though I ended up using the PPD for the Bizhub C353 and it seemed to work correctly. This setup allows printing PS and plain text files. Won't work with PCL streams. That's another subject. Don't forget to add the Bizhub to the HOSTS file. Need any additional help, just reply. I spent considerable time getting this to work (client had no IT department) and it's relatively fresh in my mind.
