View Full Version : P6035 service mode
selig67
03-12-2018, 10:13 PM
I can print out the service status page, but how do I adjust the settings? Doesnt seem to have a way to access it. Unless you have to start up in service mode?
thanks
Santander
03-13-2018, 12:56 AM
thanks
What setting(s) are you trying to change? The service mode is not like a copier. If you are trying to change a setting to correct a problem what is the problem? A little more info would be helpful
selig67
03-13-2018, 08:21 PM
I am trying to see if this Kyo can be set up with two tier color meters like the bigger boxes. line 77 of the service status page shows what could possibly be the way to change it. Is this service status page just showing what the machine is set for from the factory, or can it be changed?
GeneOR95
03-14-2018, 02:00 PM
General Technical Bulletin #97 Explains how to set this using a PRESCRIBE Command. The relevant section is three pages.39129
