View Full Version : 7255/7155 DC power supply cooling fan
selig67
09-18-2008, 10:44 PM
Does anyone know where to get JUST the fan for the power supply? Konica only offers the whole PS when only the fan is needed.
RockETop
09-19-2008, 12:42 AM
Nope, the fan is not available alone. We use used fans from scrapped machines with about the same specs and splice them in. We have had great success with this.
Albonline
09-19-2008, 08:07 PM
same here, use a 24volt fan and see if you dont get a failure code.if not your good to go.
Haroldbfix
09-26-2008, 05:59 AM
If the fan is just noisy we have had great success with removing the label and lubing the fan with synthetic oil, they will never call back.
KM GUY
08-20-2009, 06:13 PM
If you have access to a KM DI2010_2510_3510 that has a an AFR-19 on it you can use the cooling fan in the document feeder to replace the power supply cooling fan. I have tried it and it works. At least then you can order a replacement fan from the manufacturer.
