View Full Version : Miscellaneous Bizhub C452 Specific error
ncbabak
03-26-2018, 10:57 AM
Hello Friends
I have a problem in konica c452 Specific noise on prints,like test below
39248
I checked transfer, fuser,Images
In your opinion Is it possible firmware or NvRam?
Someone can help to fix this problem
Thanks!http://www.copytechnet.com/forums/images/icons/icon6.png
copyman
03-26-2018, 02:02 PM
Go into service and print out separate color test prints. The color that shows the lines need to replace that Image unit or black drum since that drum is sold separate unlike the color IU's where drum is inside unit.
ncbabak
03-26-2018, 08:56 PM
Thanks dear friend for answer
When prints separate color test , prints are ok
but when print picture or test print error is still come back
blackcat4866
03-27-2018, 12:51 AM
I see the flaw equally in all colors, especially visible in the 30% and 80% fill blocks. For it to affect all colors equally it would have to be primary or secondary transfer. Which way did the paper feed? If the voids are crossfeed (Letter-R, SEF), you might have a primary transfer drive problem. =^..^=
ncbabak
04-08-2018, 05:40 PM
thanks all
The error was removed by replacing the black drum
While there was no scratching in the drum surface
:cool:
copier tech
04-08-2018, 06:03 PM
thanks all
:cool:
Interesting fault, thanks for the update
