View Full Version : IP-601
optik
09-19-2008, 10:05 AM
I need a manual (Service Manual or Operator Manual). I cannot change the IP. The printer is OK, it works. It`s prints from the computer but the IP is something like that... 10.0.0.104 and my nwetwork use now 192.168.0.xxx. Heed help :) Thanks.
Specilist KVN
09-19-2008, 03:50 PM
Konica Minolta Business Solutions | Help Desk (http://help.bt.konicaminolta.ca)
You can get the Controller manual there, click on the "Knowledge Base" link.
Or just log into the 601 through your Web Browser by typing in the IP address. (Fiery.1 is the usual password).
Click on the webtools icon, this will bring up a pop-up.
Click on the setup button, this will start a java based applet.
In there you can configure the network settings required.
You can also do it by logging in the an admin thrpough Command Workstation and under the server menu you will se "setup".
You need to apply AND reboot the server after any changes.
Albonline
09-19-2008, 08:50 PM
password on that unit is (sysadm)
kmcopytech
09-21-2008, 04:26 AM
I have the IP-601 service manual,
Forum to upload???
Haroldbfix
09-26-2008, 06:50 AM
Is that for the 7075 or 7085 I forget.
If its the 7085 you change the IP addres through though op panel in the controller settings. If its the 7075 you crossover directly into the controller using the current ip address and change it that way
