View Full Version : Konica Minolta Bizhub C458 B4 Size problem
georgeske
03-30-2018, 04:09 PM
Just got this printer and i have a problem:
I try to print B4 size (250mm x 353mm) but the printer's driver for B4 setting have 257X364mm.
Also the trays recognize for B4 257X364mm.
Is there any way to "change" the setting in printer and the printer driver?
Thanks in advance!
blackcat4866
03-31-2018, 01:52 AM
257x364 is RB4, or B4 uncut. I have no idea why it might display that way. =^..^=
copier addict
03-31-2018, 12:57 PM
Thanks in advance!
You could create a custom size on both the machine and print driver
georgeske
04-01-2018, 07:52 PM
The problem is that in B4 size i print carbonless forms and in carbon copy function accept only standard sizes...
blackcat4866
04-01-2018, 08:01 PM
Ok. So don't select RB4. Select B4. Both are standard sizes. =^..^=
georgeske
04-01-2018, 08:04 PM
But in my printer driver B4 is 257X364mm...:D
blackcat4866
04-01-2018, 08:09 PM
You might re-check that. Does it say RB4, Uncut B4, or Wide B4?
georgeske
04-01-2018, 08:13 PM
No.. Have only B4 (257X364mm) and b4W (262X369):p
blackcat4866
04-01-2018, 08:55 PM
hmmmm... maybe reload the driver? Sorry, I don't have a driver to look at now.
Oh, That's JIS-B4! You need ISO-B4. Big difference. =^..^=
georgeske
04-01-2018, 09:30 PM
I tried pcl and ps driver, same result.. Maybe is firmware thing?.. because also the printer "read" for B4 257X364mm
blackcat4866
04-01-2018, 09:39 PM
JIS-B4 is a Japanese paper size. ISO-B4 is the recent world standard. Are you using the correct print driver for your world region? Is the proprietary software written for your world region? =^..^=
georgeske
04-01-2018, 09:52 PM
I checked. Both driver and machine setting (in service mode) is for Europe area.. I also noticed that each time driver "connect" with printer possibly to read the printer's configuration..
blackcat4866
04-01-2018, 09:59 PM
Yes the driver communicates settings with the printer via SNMP. If you're using the standard Konica Minolta driver you should be able to create a custom paper size 250 x 353. You can name it anything you like (I'd call it "ISO-B4").
