jonhamil
04-03-2018, 11:16 AM
Hi
I have an Ineo+ Develop 353. Recently in the middle of a long print run, the yellow toner ran out:
39316
Not a problem I thought - and went to get the spare that I had bought. A genuine Konica toner:
39317
To my surprise, whilst this did slide in, it didn't fit in the printer as the tabs on the front are arranged differently.
I did notice that the part numbers were subtly different on top. Although googling these numbers brings up 0 results:
39320
So, I went on Amazon, found an aftermarket toner that appeared correct:
39318
Tabs in another configuration again on this one!
So, I now have 2 options and here is my question:
1. Use the toners that I have got. Slice off the tabs necessary to make them fit and swap the chip over from the old one. Is that all there is to it? Is this likely to work?
2. Order a 3rd replacement that does actually fit. Can anyone recommend a reliable supplier that gets it right please?
Here is the toner cavity in the 353:
39319
Any advice would be very much appreciated.
Many thanks in advance,
Jonathan
39316
39317
39320
39318
39319
Jonathan
