copyman
04-03-2018, 06:53 PM
This has been an ongoing problem for around 6 months. Installed new drum for lines. About a month later customer calls for lines again. Go there and waste toner is built up inside drum cleaning unit. Vacuum out check that auger is turning reinstall and all is good. This has happened 3 times already even after a new OEM drum & waste box. It looks like the cleaning unit gets drive from the developer unit? Developer unit was also replaced last year.
Next time there I need to jump front door interlock and verify that cleaning unit auger is turning, I suspect it's not.
Anyone ever see this before?
