View Full Version : CQ color registration
jackson007
04-04-2018, 06:55 PM
dear friends,today I visited a machine.that is bh c308 having color mis registration about one inch differance for each color.
but back ground some black lines thought the paper.
i cleaned idc sensors,checked harness.
checked ph unit ribbon cables.but no change.
I attached sample.
plz give me some solution .
jackson007
04-05-2018, 04:05 AM
plz try to give solution
Phil B.
04-05-2018, 02:51 PM
I attached sample.
wow... you need to get the line issue straight before trying color registration.... all that mess is confusing the registration sensors.
look at black drum/dev unit for the lines... maybe even a HVPS issue
agudmove
12-03-2018, 04:32 PM
I have this exact problem, did you get a fix for this. 41204
allan
12-03-2018, 04:58 PM
Looks digital. I would inspect connectors and stuff on the boards and laser. Could be a unit.
inutelkamo
12-05-2018, 05:25 AM
Its too wide for color registration.
Any warning codes on the panel?
Check wires, flat cables, disconnect/reconnect if possible.
I have one issue, with magenta sagging too wide from black, replacing the PH solve the problem.
naren parashar
12-05-2018, 03:41 PM
I attached sample.
plz give me some solution .Dear ,
Remove the PH unit from machine and opened it and remove the Polygon motor cover and cleaned the polygon motor with soft cloth And fix it back in the machine.
Your problem will be solved.
100% [emoji106]
Sent from my Redmi Y2 using Tapatalk
naren parashar
12-05-2018, 03:43 PM
look at black drum/dev unit for the lines... maybe even a HVPS issueNo,
it is not related to those parts but the only problem of due to dusty PH unit polygon motor.
Just cleaned that and thia problem got fixed.
