View Full Version : KM 2552ci - C4201 error
copier tech
04-04-2018, 09:19 PM
Hi all,
Facing error C4201 on a 2552ci with just 50k on it.
I updated the firmware & checked the laser connections as sugested the the manual, no luck.
I’ve ordered a new laser unit.
Any other sugestions please!?
blackcat4866
04-05-2018, 12:06 AM
Laser codes on Kyocera can be caused by poorly actuated doorswitches or resistance in the doorswitches, or primary charge shorting. Check those things first. They're much more likely and much less expensive. =^..^=
copier tech
04-05-2018, 08:16 AM
Thanks for your reply.
I removed & checked the transfer unit while on site.
Any door switches in particular? as i'm not getting any 'door open' message, machine comes to a ready state it's only when I do a copy or print the error appears.
craigster
04-05-2018, 04:45 PM
here is something I found on Kyocera site!!
copier tech
04-05-2018, 05:56 PM
Awesome, thanks
copier tech
10-19-2018, 06:09 AM
did you find out what the issue was
Hi,
I replaced the laser unit this resolved the issue.
We sent it back under warranty.
