View Full Version : DF617
jonpaul
04-05-2018, 10:52 AM
We have been having problems with the DF 617 on c220 range where it pulls in multiple sheet .Even after changing all the rollers and giving a good clean it still does the same.Is there an adjustment that I m missing?As ever thanks for any suggestions.
Toxic
04-05-2018, 11:38 AM
Separation roller replaced?
Did you put in place correctly separation roller assy spring?
If i remember good,spring have several pressure positions,try to change.
Maybe try to replace A0HT561100 Torque limiter if nothing helps.
3ktlc
04-05-2018, 01:40 PM
On most KM DF's, the torque limiter seems to cause this issue frequently.
Don N.
04-08-2018, 10:25 PM
Lower the sep. spring tab under the tray to the bottom, least pressure position.
