View Full Version : Konica Minolta bizhub 162
zoraldinho
04-05-2018, 02:42 PM
Hi
Not familiar with Minolta.I want to replace the drum. Is anyone so friendly and tells me if I can buy and replace the complete unit? I would not like to change the blade and drum in the field for the first time....:o
copier addict
04-05-2018, 05:37 PM
Hi
It looks the same as a BH181. If it is you can order the IU but it doesn't come with drum or dev. These need to be ordered separately and installed into the IU. Then you would need to install it into the machine, clear drum and dev counter and run an F8. I would suggest you try to find a service manual.
If it isn't the same as a BH181 then disregard all of the above.
Synthohol
04-05-2018, 08:44 PM
4519-601 is the drum unit part#
8936-488 bag of developer.
Simple Google search
If the DV unot itself is bad you will have to get a part number from someone across the great pond as that model is not sold in the USA.
Toxic
04-07-2018, 09:31 AM
In Europe we use this parts numbers
A08ER70100 IU Assy
8936493 DV-110
4021029701 DR-114
@Synthohol
This appear to be DR-113 and dont fit to Bizhub 162 as i know...
zoraldinho
04-09-2018, 07:38 AM
A08ER70100 IU Assy
8936493 DV-110
4021029701 DR-114
@Synthohol
Great info Thanks!
