christcommunitychurch
04-10-2018, 02:25 AM
Just replaced the fuser, transfer belt unit and the spongy roller in the door that presses against the transfer belt in our C451 with less used units out of a second hand C451 we purchased. On rebooting the printer is stating there is a misfeed detected and indicates to check the bypass tray, tray 1, tray 2 and tray 4. There is no paper in there as we haven't printed anything. Opening and closing the trays and the door does nothing. Usually when there is a misfeed or jam and you open and close a tray it will be removed from the display as an area to check but this is not occurring. I have tried putting the older fuser and transfer belt unit back it but that doesn't resolve the issue. Tried to trouble reset and power cycle but the problem persists. I'm guessing this is some kind of sensor issue caused by replacing the fuser or the roller as I have taken the transfer belt unit out before and not had any issues. Also it doesn't show up on the jam history list in service mode so I don't have a jam code. Any suggestions on what the problem is and how we can fix it?
Thanks in advance.
Thanks in advance.
