View Full Version : Miscellaneous wierd random image shift on duplexed side
zubinn
04-14-2018, 12:27 PM
c7000 konica machine, printing simplex is okay.
Printing duplex on the reverse side the image randomly shifts 5mm inboard perpendicular ( 90 degrees ) to the paper path.
39425 39426
allan
04-15-2018, 06:37 AM
You shift is in the "main scan" direction.
Clean or reconnect the centering sensor.
Don't know these well.
Could be skewing before the registration and shifting after the loop.
Don't these machines jam if the centering is out too far, soft-switch turned off?
zubinn
04-15-2018, 11:16 AM
how can i check if the image shift is due to a mechanical issue i.e. the paper physically is shifted higher.
allan
04-16-2018, 04:33 AM
check at the paper exit
