View Full Version : c3350 Shows jam at right hand door and FF FF code
Hi all
Just had a used C3350 traded in
Machine displays a Jam at the right hand door and code FF FF anyone come across this
Have checked paper path sensors and switches all seem ok
Any advise would be welcome Thanks
joelea
04-18-2018, 11:43 AM
Hi all
Id be trying firmware have you got any?
3ktlc
04-18-2018, 01:42 PM
I agree on trying firmware. We just had a C3851fs jamming and firmware took care of it.
Turned out to be a hardware fault
was a broken wire to the exit sensor
n25an
12-15-2018, 12:23 AM
which firmware did you use to fix this issue... ???
n25an
12-15-2018, 01:11 AM
C3851Series_A92E0Y0-F000-G00-N5.exe
Release Date: 6/26/2017
Version: G00-N5
was this the firmware ??
3ktlc
12-17-2018, 08:01 PM
Pretty sure that was it.
R.guillermo
12-23-2021, 04:40 PM
[QUOTE = Elmo; 602089] Resultσ ser una falla de hardware
era un cable roto al sensor de salida [/ QUOTE].
Hello elmo where is that sensor contact me since I have the same problem and it is the same model
Synthohol
12-24-2021, 12:05 PM
its PS7.
https://www.copytechnet.com/forums/attachments/konica-minolta/51223d1640347543-c3350-shows-jam-right-hand-door-ff-ff-code-ps7-jpg
R.guillermo
12-30-2021, 04:50 PM
its PS7.
God bless you again thanks for the previous help from my heart, I was already checking the sensor and all the rest in that area and the connectors and their cables and even replaced some since I have another equipment of that for feet but the paper jam error FF -FF still there is help please
R.guillermo
12-31-2021, 01:45 PM
God bless I managed to clear the paper jam error and now it is the 2152 error that is causing me annoyance but I am trying to solve it some help
Synthohol
12-31-2021, 03:13 PM
3.5.14 2152
(1) Contents
Trouble type
1st transfer pressure/retraction malfunction
Trouble code
2152
Rank
B
Detection timing
The 1st transfer pressure sensor (PS9) does not change its state from one corresponding to the retracted
position to the pressed position within a predetermined period of time after the 1st transfer pressure solenoid
(SD1) has been energized.
The 1st transfer pressure sensor (PS9) does not change its state from one corresponding to the pressed
position to the retracted position within a predetermined period of time after the 1st transfer pressure solenoid
Trouble isolation
Relevant electrical parts
Main motor (M1)
1st transfer pressure solenoid (SD1)
Printer control board (PRCB)
(2) Procedure
Step
Action
Control signal
Location of electrical components
1
Check the connector between M1-PRCB CN9 for
proper connection and correct as necessary.
2
Check the connector of M1 for proper drive coupling
3
Check the connector between PS9- PRCB CN12 for
4
Check the connector between SD1-relay CN85-PRCB
CN12 for proper connection and correct as necessary.
5
PS9 I/O check, sensor check
PRCB CN12-3 (ON)
15-C to D
6
SD1 operation check
PRCB CN12-12 (REM)
15-E
7
M1 operation check
PRCB CN9-3 to 6
15-B
8
Replace M1
9
PRCB F4 conduction check
10
Replace PRCB
Link to the wiring diagram (N.1. bizhub C3850/C3350)
Link to the wiring diagram (N.2. bizhub C3850FS)
Link to the layout drawings for related parts by each trouble code (S.12. 2152)
R.guillermo
01-13-2022, 04:14 PM
3.5.14 2152
(1) Contents
Trouble type
Trouble code
2152
Rank
B
Detection timing
• The 1st transfer pressure sensor (PS9) does not change its state from one corresponding to the retracted
• The 1st transfer pressure sensor (PS9) does not change its state from one corresponding to the pressed
Trouble isolation
• Main motor (M1)
• 1st transfer pressure sensor (PS9)
• 1st transfer pressure solenoid (SD1)
• Printer control board (PRCB)
(2) Procedure
Step
Action
Control signal
1
2
3
4
5
PRCB CN12-3 (ON)
15-C to D
6
SD1 operation check
PRCB CN12-12 (REM)
15-E
7
M1 operation check
PRCB CN9-3 to 6
15-B
8
Replace M1
9
10
Replace PRCB
• Link to the wiring diagram (N.1. bizhub C3850/C3350)
• Link to the wiring diagram (N.2. bizhub C3850FS)
• Link to the layout drawings for related parts by each trouble code (S.12. 2152)
God bless you, thank you, I was able to solve this but I have a paper jam error 11-02 in tray 1 and the paper does not even come out of the tray and in tray 2 the paper is halfway through and it gives me an error 30-03
Synthohol
01-13-2022, 05:15 PM
Tray 2 sounds like a paper size mismatch and the 11-xx in tray 1 just change the rollers and make sure the backstop for the paper actually helps push the paper towards the rollers when lifted.
I've put a piece of sponge behind the mylar for additional support when lifting.
tsbservice
01-13-2022, 06:43 PM
I think those paper trays were modified heavily because of falling apart and paper jams.
