View Full Version : Miscellaneous Konica C6501 developer problem
stakid
04-24-2018, 06:15 PM
Hi
I have the problem you see in the pictures only in magenda developer.
The problem started suddenly and only in the front edge. The rest print is very good.
Some one with the same problem?
3950139502
Synthohol
04-24-2018, 10:50 PM
there is something behind the shutter or doctor blade or one of the magnets inside the mag roller has been dislodged.
did you recently change the DV? did you take out the screw disengage the shutter and spin the roller to help expel any debris as its vacuumed?
stakid
04-25-2018, 08:10 AM
No i have never changed developer.
Today i will change it and i will do a good clean.
If it is a magnet problem do i have to change the roller?
Thanks.
Toxic
04-25-2018, 08:23 AM
This is well known problem on this machines,toner depleting.
I dont think something is damaged phisicaly.
What is developer life now?
Just change developer as you plan and try use this settings from troubleshooting.
39512
danetime
04-25-2018, 02:16 PM
As said replace Developer.
