View Full Version : Fiery showing FF on c6500 ic408
swaggen
04-27-2018, 05:46 PM
Looks like I need a hard drive or Reload the software and my tech is 3 days out.
I am looking to operate the printer without the controller , direct from server or PC.
Is that possible? I am being told yes and No.
I have gone into the dip switches DIPSW 2-1 (1) On
Set my NIC Ip to a range that is will pick up.
Connected to the appropriate LAN on the machine.
Is it futile? Can you only print via a controller?
Toxic
04-27-2018, 08:07 PM
As i know it is not possible to print without controller.
And this is logical because why people would buy a expensive controller if it can be printed without it.
Synthohol
04-28-2018, 01:22 PM
do you have/need system software?
i can help you out if you are a contributor to this site.
just an offer.
swaggen
04-28-2018, 08:11 PM
just an offer.
Sure I would like to contribute and I appreciate the help. How do I do that best?
Synthohol
04-28-2018, 11:39 PM
top of the forum.
ill send you the links to my server.
ipicopier
09-29-2018, 12:39 AM
Hi,
I will contribute if its possible to send a download link to the c6500 ic408, my RIP went crazy and have been trying to get this file..
Thank you,
Rak
Synthohol
09-29-2018, 02:05 AM
ill send you the link when i see the badge :)
thanks for considering.
btw ask anyone here, i always follow through.
Copy Bargain
01-31-2020, 06:55 AM
Fiery boots up and shows FF error sometimes, but always works if I reboot the printer and then the fiery while the printer is warming up. BUT, I can't send any files much larger than 1MB to the fiery!!? And if I send anything larger it takes hours to load into the fiery, OR the fiery disconnects.
Archived jobs in the fiery print just fine, is this a system software issue? A HDD issue? Or should I just upgrade to the external fiery ic-305?
I don't have the system software, and I'm not sure of what HDD to get if I have to replace that too.. I can get the ic-305 for $1300 if I trade in my malfunctioning ic-408 from an ebay seller --> Konica Minolta FIERY IC-305-PLUS* Server *UPGRADE* from IC-408 X3eTY2 Controller | eBay (https://www.ebay.com/itm/Konica-Minolta-FIERY-IC-305-PLUS-Server-UPGRADE-from-IC-408-X3eTY2-Controller/262071445151?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2763.l2649)
Not sure what to do as I have to print many jobs this next week.. :/
Any feedback/assistance would be greatly appreciated! :)
Thanks!
Synthohol
01-31-2020, 12:40 PM
just an offer.
Phil B.
01-31-2020, 01:09 PM
it's true.. he has the sweetest golf swing follow thru I've ever seen! :D
seriously tho... If Synth says he'll send the files when you Contribute, you'll get them!
sorry early morning humor. :cool:
Synthohol
01-31-2020, 03:45 PM
I have for the ic408 versions 1.1 and 2.0
Do not try 2.0 unless you have had the bios and ram upgrade already installed.
Just 1 contributor badge away from getting that fiery up and running ;)
Copy Bargain
01-31-2020, 05:16 PM
Thanks guys! I'm happy to contribute! Now how do I go about reloading the software on the the "Bolt-On" IC-408 Fiery server??
Best,
Romeo
Copy Bargain
01-31-2020, 05:31 PM
Currently, my Server Info is:
Password Enabled: Yes
Memory (MB): 1024
Software: EFI Fiery System 8 Release 2
Version: 2.0
Disk Size (MB): 60016
Free Disk Space (MB): 51937
Synthohol
01-31-2020, 06:16 PM
I sent you a link to the system ver 2.0
Enjoy
And a 2nd pm for the instructions.
Thank you very much for contributing!!!
Copy Bargain
02-01-2020, 08:48 PM
Enjoy
Thanks Synthohol! I didn't even need to restore the software! When reading the instructions, I ran across the section for printing out the configuration settings to prepare for the reconfiguration, and out of curiosity I started comparing the settings from now to 3 years ago and noticed that the darn network Ethernet speed was incorrect!!
It's been 5 months holding off and thinking my Fiery went bad! What a relief!!
Thank you so much though! You still helped lead me into a solution, and I still have the software JUST IN CASE!
mariuscmr
07-10-2021, 02:24 AM
I'm also interested in the software image after a HDD crash. I managed to clone the OS and Backup partition, but the one labeled "Fiery" has got a lot of bad sectors and unreadable files. It's for Fiery X3eTY2-10. Can I get it, please, if I also contribute?
Thank you!
Synthohol
07-10-2021, 04:54 AM
Still applies.
Walterj
07-13-2021, 05:38 PM
good day
The error presented by your fiery must be due to the defective HDD, I recommend you replace it and load the operating system.
You can write to me at walvaradocruz@gmail.com
Greetings.
Synthohol
07-13-2021, 08:29 PM
you are responding to a user's post from 3 years ago.
please check the date of posting if you are quoting someone.
