View Full Version : C220 USB port
paulrid
05-04-2018, 01:37 PM
Hi all,
i have been been to a c220 this morning where the front USB port doesn't seem to be working, when I insert a USB stick nothing happens not even the graphic at the bottom of the screen. It also doesn't show up as external memory from user box, i then tried my movie data file USB in system 2 and nothing. What I don't know is if there's any s/w switches or anything else to disable these ports?
any info much appreciated.
thanks Paul.
mo0651
05-04-2018, 01:54 PM
USB must be 2.0 or less compatible on this model. I have seen Some USBs work in some models and not in others.:cool:
paulrid
05-04-2018, 04:24 PM
Thanks mo but I'm sure it's not the USB sticks I've tried as there are other c220 at this location which work fine with them.
paul.
Bix
05-04-2018, 04:46 PM
Have you enabled the USB port in Administrator?
Utility > Administrator > Password > System settings > User box settings > External Memory fuction settings.
After switch OFF to ON.
paulrid
05-04-2018, 05:35 PM
Thanks Bix but they are all set to on.
paul.
Synthohol
05-04-2018, 06:25 PM
That port routes to the back on the mfp board. Unplug the cable and try the usb direct into the board.
paulrid
05-07-2018, 09:30 AM
Hi synthohol next time I'm there I'll try that but.
Thanks Paul.
paulrid
05-09-2018, 02:07 PM
I was there today and even though last visit I moved the lead from one USB port to the other I didn't try the USB stick in the rear port but as advised today I did and guess what it worked 👍
I may look at a scrap machine and see where the routing for the front port goes and see how easy it is to change but for the moment they can use a rear port.
thanks Paul.
