Di 251 Vs bizhub 250
  • moonwalker3778
    • Jun 2008
    • 87
    dear all,
    is Di 251 fuser roller same with bizhub 250 fuser roller?
    thanks in advance
  • lvangsnes
    The rollers are not the same.
    • ukyo
      • Aug 2008
      • 51
      Check their part number just to be sure..
      • mitchl
        • Apr 2007
        • 501
        The rollers may very well be the same but the overall housings are different....... I think, I'm not at the office so I cant check right now but will later.
        • lvangsnes
          I looked up the part numbers and they are different.
          • fixthecopier
            ALIEN OVERLORD
            • 4714
            There is nothing the same from a di250 to a di251 except the top paper tray the image unit and the transfer area.
            • ukyo
              • Aug 2008
              • 51
              If they don't have the same part number, ergo, they're not the same.
              • ni311
                • May 2008
                • 658
                You cannot tell that two spare parts are not the same just checking the code number. These codes have all kind of equivalents. So, you'll get the best answer only comparing physically one with another.
                Konica Minolta Error Codes - Explanations and Solutions
                • ukyo
                  • Aug 2008
                  • 51
                  That's ok if you have the other pare part to compare.
                  • mitchl
                    • Apr 2007
                    • 501
                    I went to the parts room and did a comparison of the 2 aforementioned rollers.......... Not the the same, not even close the 251 UFR is well over a 1/4 inch bigger in diameter.............. End of debate. But keep in mind KM uses some of the same parts on a new model as the previous model and they do change the part numbers for clarification reasons so comparing is the only real way to know.
                    • moonwalker3778
                      • Jun 2008
                      • 87
                      Thanq
                      Hi all,
                      thanq for the replying me.
                      can u confirm me Dialta 3510i and bizhub 250 fuser roller are same
                      Thanks in advance
                      • mitchl
                        • Apr 2007
                        • 501
                        I dont believe they are the same rollers.
                        • ni311
                          • May 2008
                          • 658
                          It seems to me that you're waiting for someone to tell you that the rollers are the same even if everyone else until now told you the opposite...
                          • mjunkaged
                            • 379
                            Rollers NOT the same!
                            NOT the same. Not to mention the '0' series tends to melt and i never had any success rebuilding them.....
                            Don't bother.
                            • Hansoon
                              • Sep 2007
                              • 3350
                              According to Katun are the UFR's for the Bizhub 250, 350 and Di-2510, 3510 the same. Their part #24317
                              The Di-350 is very different, the Di-351 different again and even the 25cpm machines of those both series are officially different from the higher speed series although we always used the 35cpm UFR for the 25cpm machines both as well. The wall thickness of the 25cpm machines is a little less.
                              I'm almost confused myself now......
                              Hans
                              “ Sent from my Intel 80286 using MS-DOS 2.0
                              https://www.copytechnet.com/images/smilies/biggrin.png
