View Full Version : ECOYSYS 6525 Fax
Raymann
05-25-2018, 09:42 PM
Finally plugged in the fax card on this machine. When I use it it hanges on to the pages one at a time. wont go into memory When we send something sends one page then next page..........
Any Ideas thanks Ray
copiertec
05-26-2018, 01:07 AM
Assuming you have followed Kyocera's recommendations if it is a VIOP, have you tried going into U660 and changing PSTN to PBX?
go to fax setting rx turn fax bulk
will receive to entire job and print them out
Raymann
05-26-2018, 05:41 PM
not sure what a viop is or what the recommendations are. I have been in contact with tec support from Kyosera and have slowed down tx speed to no avail. I can try the pbx switch I will try anything at this point........Thanks
Raymann
05-26-2018, 05:42 PM
I am willing to try this even though I am having issues with tx not receiving...Thanks
copiertec
05-26-2018, 07:33 PM
Oops, my dyslexia kicking in, VOIP (Voice Over Internet Protocol)
Sound odd check adf is set for sound like single mode should be multi pages also check default settings. You can do a reset on fax is 600 something should everthing back to factory settings.
Raymann
06-05-2018, 04:04 AM
Well today I went out and in the user menu. I checked the bulk fax mode and it was on. However a I turned off the tti in the user menu and it reads the fax job at once. Not sure what the hell tti is but that fixed the issue....................??????????
Santander
06-06-2018, 01:27 AM
TTI is just shorthand for Transmit Terminal Identifier, that is the information that is at the top of every page the unit sends. It is required in most countries. Actually turning off the bulk fax mode is what solved your situation as it collects fax transmissions to send in bulk as opposed to individual jobs.
CleanTheSlitGlass
06-06-2018, 02:00 AM
In MM, Try turning ECM off too, v.34 needs to be on or off (don’t quite remember which, but play around with it). Might help in combination with messing around with reception speed.
Raymann
06-06-2018, 05:22 AM
interesting...but I did not turn off the bulk fax mode just the tti..........I shall investigate soon......
