tonerjockey
05-31-2018, 05:04 AM
Hi Guys, i was hoping that someone can remember what things could be a common cause on this bad boy. the machine only has 886,000 copies on it.
Four times in the last 5 months, or 33,583 copies, it ran paper into the cleaning section. first time December, then Jan, then April and now may.
I have checked for any error codes in service mode, as it never throws any when it does this. just customer calls complaining about black lines. one was for erase lamp, at the count when i was there one of the times. i likely left the plug off inadvertently. then a bunch for the charge cleaner motor, but that had a broken cleaner block that was replaced back when.
I changed the drum claws and solenoid in January. it makes great copies, and the machine is pristine.
i was thinking transfer separation corona assembly, since the transfer wire insulation end blocks are not spared. its a small doctors office so i don't feel great about shotgun troubleshooting, since i don't have a parts machine to use.
if anyone can offer any advice i would appreciate it. the good guys at Hytech are thinking control board, high voltage board or the ADU board.
thank you very much, Jim
