View Full Version : CQ 8 series drum life
EarthKmTech
06-11-2018, 10:49 PM
Can they be extended, yes or no?
I already know the answer from my own experience, having to keep them in the car and change them for customers for "lines on print" on a regular basis.
However being told "its not happening anywhere else" is the usual reply.
So, "is it happening anywhere else?"
blackcat4866
06-12-2018, 12:39 AM
They seem to be making the manufacturers quoted yield ... just barely. Not twice to three times the stated yield like the e series. The major difference is the change from charge wires to charge rollers. It must be the physical contact that makes the difference. =^..^=
EarthKmTech
06-12-2018, 01:18 AM
This is also my experience.
Hopefully some more people can add their experiences too.
allan
06-12-2018, 02:16 AM
Just gets past yield.:(
rrrohan
06-12-2018, 03:19 AM
Least the yield is correct. We are so use to drums exceeding life we almost expect it now so when it only manages maybe 110% we fill ripped off.
Woxner
06-12-2018, 03:32 AM
pretty much advertise yield . once in awhile you get lucky and it goes longer
copier addict
06-12-2018, 02:48 PM
We average about 1000 over advertised yield. Better than not making it to yield I guess.
Changing from a charge corona to a charge roller is the direct cause of this, and the only reason KonMin made the change as far as I can see. They give some phony ozone reduction reason, but getting $200 every 100k instead of every 200k is the real reason.
https://media3.giphy.com/media/VTxmwaCEwSlZm/200.gif
allan
06-12-2018, 05:50 PM
Mmm does a DR512 fit in there?
blackcat4866
06-12-2018, 07:54 PM
Primary charge voltage will be significantly lower for a charge roller than a corona wire. I would expect black copies (assuming you could make it fit). =^..^=
Kidaver
06-12-2018, 10:04 PM
Yeah all this changing to charge rollers for ozone tree hugging green stuff has just made drum life awful. Also you can't really pop these rollers out like on a Kyocera and clean all that built up paper dust that accumulates on them due to cheap paper.
larweedad
06-12-2018, 10:42 PM
I had one that showed the lines at 2 % life left.
AjitN
06-13-2018, 02:06 PM
TO extend the life, frequent cleaning of charge roller is the only option, which depends upon quality of paper and environmental conditions.
Brett GS
06-18-2018, 07:28 PM
Havent been that lucky to get them to run over life,had many fail long before they were due.
jamesyboy
06-19-2018, 09:43 AM
you can modify a k drum to fit for a colour which takes the cost down
and yes its the charge rollers
REGSIS
06-26-2018, 06:38 AM
I had one DR512 CMY drum at 35% life left that sucked out cyan developer. Burned charge corona and matted drum surface at 4 places, 2 at front 2 at back. Transfer belt burned at same spots, black drum matted also but much less. Black drum charged corona not burned - life 65% left.
All OEM parts and toners. Everything inside manufacturer's life.
Has anyone experienced this developer sucking on 8 series yet?
Since there's no charge corona, is a charge roller a solution to this issue?
Tech Helpdesk
06-26-2018, 01:35 PM
We are experiencing toner sticking to the drum surface around 50% of life and we also are getting white lines caused by toner getting stuck on the charge roller.
Is anyone else getting these problems ?
copier addict
06-26-2018, 01:58 PM
OEM toner?
Tech Helpdesk
06-26-2018, 02:06 PM
OEM toner?
We have some customers on OEM and some on compatibles.
I have recently replaced in a bizhub 458 (DR-313K).
The manual indicates the replacement every 155,000 copies. The printer started making bad copies at 140,000 (horizontally).
The printer warned me in advance with the monitoring software (first call). The MFP did not alert the customer to the screen. (I guess because there are still 140,000 copies).
