wild140
06-15-2018, 05:09 AM
Original issue was it would feed one copy all the way out but show a misfeed found exit actuator tip broken off , after replacing that I now have a constant misfeed showing at the upper switch of the duplex unit. Switch tests good with a meter , The unit does not recognize the switch changing state , Replaced paper feed board . No difference, Anybody seen this before? Jam 14 indication on screen,
