View Full Version : bizhub C33851fs
3ktlc
06-26-2018, 09:51 PM
While the machine is pushing a set of papers to the exit tray, the next one is coming in. Sometimes, it doesn't stack correctly or causes a jam. Anyone see this before?
copier tech
06-27-2018, 07:43 AM
Most likely damp paper causing this issue especially if the prints come out a bit curly.
Albonline
06-27-2018, 04:26 PM
have one doing the same thing here. suspect the dup unit isnt moving the first sheet of the set fast enough to clear in time.have had it crumple paper under the fuser a few times.
3ktlc
06-27-2018, 06:04 PM
Now this machine won't even run 1 sheet. It jams right at the exit. Any ideas on this?
Albonline
06-27-2018, 06:53 PM
try stapling. if it works then i would be looking at things that could slow down paper travel, eg motors clutches gummed up bushings.
3ktlc
06-27-2018, 09:26 PM
Nope. Still jams at exit
3ktlc
07-13-2018, 05:45 PM
Turns out it was a couple of problems
Exit actuator was broke.
Rails in finisher were bone dry causing the guides to struggle to move.
Only 21k on this machine.
Albonline
07-16-2018, 01:37 PM
same problem here, dry rails causing finisher to slow. I am trying plus guard on one and dry surf on another. either way lub is the fix.
3ktlc
08-01-2018, 02:18 PM
Yep. Lubing the rails is the fix. Just had another one start that. Lubed the rails and started working again. Going to be part of the regular maintenance on this machine
