View Full Version : Miscellaneous Bad Printing TASKalfa 2552ci
Tommy Chilcott
07-19-2018, 09:22 AM
Good Day.
Please assist with the following problem I have on a TASKalfa 2552ci.
After a colleague came out to assist with lines on prints, he cleaned the MC of the machine. After putting back the Dk and Dv units the machine started printing solid black and the yellow pages.
I came out and followed SB 2ND-0083 (H239).
I have done firmware and stripped and checked the HV PWB. I have stripped out the drive assy and checked all the charge springs.
Please find attached
Tommy Chilcott
bush_tech
07-20-2018, 01:55 AM
One of the techs here had a pretty similar looking fault, turned out to be HVT.
40191
copier tech
07-20-2018, 07:38 AM
Looks like the dev units are not seated correctly.
You got this issue on previous models if the white locking bar was not pushed in.
kaborwen
07-23-2018, 01:15 PM
Good Day.
Tommy Chilcott
Was your toner OEM?
Tommy Chilcott
08-16-2018, 02:38 PM
Good Afternoon Gents/Ladies.
Just to give you guys feed back on this fault.
It was a blown HV PWB. I had to change it as well as all 4 DV units.
Tommy Chilcott
bush_tech
08-16-2018, 03:17 PM
Tommy Chilcott
Thanks for the update mate
Phil B.
08-16-2018, 09:23 PM
Was your toner OEM?
please read the post.. a PREVIOUS tech was out then the problem showed.
Like one suggested ( Slim? ) check to make sure the dev units are seated properly.
