View Full Version : CS 2552ci C6600 CODE
Intone
07-19-2018, 08:47 PM
Have taken out the fuser, fuser looks good. Code resets but comes back after a while. Tried latest firmware today didnt fix it. Anyone else have this issue? Going to try tech support tomorrow. Thank you in advance.
patrickjlc
07-19-2018, 09:31 PM
Have taken out the fuser, fuser looks good. Code resets but comes back after a while. Tried latest firmware today didnt fix it. Anyone else have this issue? Going to try tech support tomorrow. Thank you in advance.It nay look good, but the thermistor or fuse might be bad giving you a code even though you reset the error. Fix it, then reset.
Sent from my SM-G930V using Tapatalk
tmaged
07-19-2018, 09:45 PM
Bulletin H178. Replaced the fuser.
Santander
07-20-2018, 12:59 AM
We have not had this issue, but the C6600 relates to the machine not seeing the fuser belt rotating for 1.8 seconds. That would indicate that the fuser is binding up and not reaching the rotation speed expected by the machine. Since Kyo only sells the fuser assembly and not any of the internal parts, you will probably have to replace the whole fuser assembly which would be covered under the warranty.
masterchill
07-23-2018, 02:12 PM
On these you can grab the bushings on either end of the fuser roller and if you can turn them separately the fuser is bad.
CleanTheSlitGlass
07-25-2018, 12:08 AM
If the fuser doesnít do the trick, look for the fuser motor all the way at the top left of the backside of the machine. On 3051 series, itís literally right under the tip top left corner.
