View Full Version : Miscellaneous Bizhub c224e - doesn't enter Service Mode
GIUBOSS
07-20-2018, 08:47 AM
Hi, I can't enter Service Mode by using the default "9272" x 4 times. I need to reset maintenance counter.
Try going via reset procedure. Then stop 00 stop 01. then 9272 x4 times
GIUBOSS
07-20-2018, 09:59 AM
I did it... i just forgot to write it on this thread. It doesn't work and i can't enter SP mode. Maybe someone else changed "9272" password
Synthohol
07-20-2018, 12:32 PM
did you try 9272 twice? someone obviously changed it.
copyman
07-20-2018, 01:13 PM
maybe someone set it to the older models password, try "12345678" or "00000000"
rrrohan
07-20-2018, 04:13 PM
Contact KM they can provide a reset key. I have done this in the past
Boltaction
07-20-2018, 10:27 PM
I always change my machines from "9272x4" to 9272x2"
rrrohan
07-21-2018, 02:33 AM
If your not gonna change password to something other than default i'd just turn of CE authentication. A customer can find both service mode access method and the default password in a 30 sec google search
GIUBOSS
07-21-2018, 10:25 AM
sorry but I will write in English with google transistor because I'm not with the work colleague, I hope understands me. I think from experience that by calling KM they point me to the nearest service center and usually send a technician behind payment. They don't say technical informations.
copier tech
07-21-2018, 11:46 AM
Enter service mode from trouble reset mode this bypasses the password.
(hold down reset while powering on)
GIUBOSS
07-21-2018, 12:43 PM
now I have collected all your advice. I'll be back to the customer in two days and I'll let you know. Thank you.
copier tech
07-21-2018, 06:01 PM
Worst case use the NVRam reset firmware 🤫
GIUBOSS
08-30-2018, 11:43 PM
Please could I have the detailed procedure and the firmware to reset the password. Regards
copyman
08-31-2018, 01:59 AM
Agree try 12345678 or 00000000. I always turn off CE password. If I do want a password I change it to 12345678 same as admin.
Anyone who changes from one of these common passwords to a unique password is just screwing their fellow techs!
Although back before I started my own biz I would of liked to change all the passwords to screw a few of the A-Hole companies I worked for:cool:
GIUBOSS
09-04-2018, 06:29 AM
i'm sorry but I try all without success, I think arrived's time to reset with the method firmware suggested here, someone knows it and can help me? Regards.
aleksander
09-04-2018, 09:07 AM
Ask the reset code key to KM.
GIUBOSS
09-07-2018, 09:26 AM
Hi, I tried but I was not able to talk to KM technical office maybe because I'm a private customer. Is the reset key different for each machine?
Phil B.
09-07-2018, 03:50 PM
clearly you aren't a tech... you should have a tech do this since you can muck up the unit quickly.
aleksander
09-10-2018, 04:55 AM
Sure. You can ask the KM technical service to reset the machine. Reset key different for each machine depending on serial number.
GIUBOSS
10-25-2018, 02:52 PM
thanks anyway, the customer has solved by typing 12345678 !!! So he says .... Greetings
blazebusiness
10-25-2018, 04:59 PM
If from trouble reset mode ----that does indeed bypass the password..........pretty good tip.
rrrohan
10-26-2018, 05:21 AM
Some features get disabled if CE auth is off.
Remote Panel is one
