View Full Version : Kyocera Taskalfa 6550ci exit unit motor stalls
carolscurriculum
08-09-2018, 05:21 PM
Hello I have a Kyocera Taskalfa 6550ci jam code 4211 I found that the exit unit motor stalls I replaced the motor same problem it spins until the paper hits it then stops. could it be a wiring harness or board?
Phil B.
08-09-2018, 07:42 PM
could be a sensor
blackcat4866
08-09-2018, 08:25 PM
Do you see any 4911, 4912, 4913, 4914? =^..^=
carolscurriculum
08-09-2018, 08:35 PM
could be a sensor
checked the sensors and narrowed it down to the exit motor I found that the exit unit motor stop when the paper hits it EVEN STARTS AT ALL I replaced the motor same problem it spins until the paper hits it then stops. could it be a wiring harness or board?
Phil B.
08-09-2018, 08:40 PM
31 years in the industry has taught me NOTHING is impossible when it comes to equipment .
yes very possible it could be a harness or board. pinched wires can cause ALL SORTS of issues.
carolscurriculum
08-09-2018, 09:17 PM
I just swapped the whole unit exit from another printer same issue I'm thinking its a board issue.
Phil B.
08-10-2018, 02:21 PM
well now by process of elimination I do believe you are correct.
carolscurriculum
08-10-2018, 05:42 PM
Now which board engine pwb or front pwb
Phil B.
08-10-2018, 06:44 PM
not knowing that unit.. i would say which ever board that assm plugs into...check your PtP in service manual
