View Full Version : Miscellaneous Bizhub 282 please wait
ecoworld
08-10-2018, 04:27 PM
Hello
I have a bizhub 282, on powering on it displays PLEASE WAIT, and does not proceed any further. Onpowering on it makes some noise - normal turning of parts noise, fuser is heating.
Any idea what can be the problem.
mo0651
08-10-2018, 04:48 PM
Check the toner bottle. It is probably empty.:cool:
ecoworld
08-10-2018, 05:32 PM
I replaced with new toner, same result.
Phil B.
08-10-2018, 05:33 PM
did you check to make sure no paper stuck somewhere?
reflash ALL system firmware
tsbservice
08-10-2018, 08:01 PM
On old Toshibas it will display "Please wait" message forever when HDD start to have bad sectors. Usually formatting will take care of that issue.
I would try unset HDD in service mode and if it boots up formatting HDD will be next step.
emujo2
08-10-2018, 08:28 PM
MFBS2 has failed, or scanner board has failed. Either way, you are gonna have a hard time finding a replacement, and the MFBS2 was manufactured for 2 different phases so you can't put a phase 1 board into a phase 2 MFP, but you can change a jumper on the phase 2 board to make it work in a phase one. You can remove the scanner board to see if it will come to ready as a test. Emujo
Synthohol
08-10-2018, 11:24 PM
december 2017 that machine is discontinued with no support.
time for an upgrade!!
Synthohol
08-10-2018, 11:49 PM
can you get into service an see if there are any codes? check the atdc level and fuser temp too.
maybe thermister is dirty.
remove the IU and separate the drum from DV unit and check the brush on the roller and coverage.
Phil B.
08-11-2018, 12:32 AM
agreed.... no support?
might as well get the customer to upgrade!
