View Full Version : konica minolta c451
karimharaka
08-13-2018, 12:17 AM
Hello,
i need help pleas, i have a c451 konica minolta it s work well but when i make a phoyocopie ftom the scanner direct it print a small squares on the paper i tried many solutions but nothing works
Phil B.
08-13-2018, 01:31 AM
Hello,
i need help pleas, i have a c451 Konicka Minolta it s work well but when i make a photocopy from the scanner direct it print a small squares on the paper i tried many solutions but nothing works
Tech or end user?
blackcat4866
08-13-2018, 11:40 PM
Perhaps you'd like to attach a sample? =^..^=
greglogston
08-14-2018, 11:07 PM
You might wanna go through the installation instructions again. Sounds like that machine is back at factory settings or something.
mincopier
08-14-2018, 11:20 PM
The machine has lost it's setting and the initial set up must be done again. This should be done by a qualified technician.
karimharaka
08-15-2018, 09:52 AM
thank you for your reply. i have changed the NVRAM how can i programe it again ?
greglogston
08-15-2018, 02:33 PM
Not helping you as I can see that you are not a qualified technician and you didn't take our suggestions.
karimharaka
08-15-2018, 06:55 PM
Hello sir,
i would like to inform you that i had changed the nvram in order to give you more information about the problem
so knwo what are the instructions should i follow to solve this problem?
Synthohol
08-15-2018, 11:06 PM
why would you change the NVRAM?
mincopier
08-15-2018, 11:14 PM
Hello sir,
Check your private messages
karimharaka
08-16-2018, 01:16 AM
because the machine would not started until i changed the NVRAM
