View Full Version : C250 Network fax to PC
kennyoleary
09-25-2008, 09:30 PM
Can the C250 recieve a fax from another type of fax machine and turn it into a file or email and send it to a PC on the network? I have looked thru the Network Fax Operation Guide and it refers to IP Adress faxing and Internet fax but I don't see how either one of these puts the fax on the PC.
pepper38_cnd
09-25-2008, 10:41 PM
Forward TX can be to anything in the address book, forward faxes to Email, SMB, Box, FTP or another fax number.
kmcopytech
09-26-2008, 01:29 PM
Gateway TX is not enabled. To enable Gateway TX, perform the following:
1\Enter Utility--administrator setting;
2\select fax setting--forward TX setting;
3\Don't choose OFF.
Good Luck!!!
pepper38_cnd
09-26-2008, 01:56 PM
Don't get confused, the instructions I attached earlier are correct (copied directly from the Users Guide), this is a C250 not a Bizhub 250. Gateway TX does not apply.
konisolver
09-26-2008, 03:08 PM
Yes you can forward faxes to electronic format. If you want to forward as pdf and not tiff make sure you have the latest firmware levels.
konisolver
Yes, you can forward faxes to electronic format. If you want to forward as pdf and not tiff make sure you have the latest firmware levels.
kennyoleary
09-26-2008, 05:38 PM
Thanks for the help. I am updating the firmware today.
kmcopytech
09-27-2008, 04:11 AM
Thank you for your correction!
I was confused,
but I should say that the setting is correct!!!
