View Full Version : BH364e contol panel
copier addict
08-15-2018, 02:22 PM
Does anyone know if the control panel from a BH364e will work on a C364e? I realise the part numbers are different, but KonMin will sometimes put different part numbers on parts that are the same.
srvctec
08-16-2018, 11:55 PM
No clue but curious.
So, are you going to try it and let us know? :)
acusso1234
08-17-2018, 12:12 AM
Yes, they are. No firmware required. Done that from a donour C224e to a 224e
copyman
08-17-2018, 12:17 AM
Good to know thanks.
srvctec
08-21-2018, 06:59 PM
I wonder if it makes a difference putting a color machine's control panel on a b/w vs. the opposite like the OP was inquiring about. My only thought is that maybe the color panels have extra stuff the b/w machine doesn't need so it works OK but if the b/w panel is missing something the color needs, it might not work.
copier addict
08-21-2018, 08:28 PM
My colleague is trying it today, so I will let you know
techie0419
08-21-2018, 09:43 PM
I'm curious how it turns out as well. I can see it making a difference with boards or possibly even drums (although a black drum *should* work in both color and monochrome machine of the same series...) but the op panel only displays the information it was sent? But I have been wrong once or twice, so it may very well happen again. Eventually. ;-)
