View Full Version : bizhub large capacity tray paper skewing...
n25an
08-18-2018, 12:58 AM
a word to the wise
if you are getting paper skewing from the large capacity tray...
both drawers...
check the paper path door on the right leading from the unit...
if you see plastic dust everywhere...
all the rollers are shifting to one side...
and are being sheared of plastic...
one of the door hinges is bent...
sure sign... the rear spring that is part of the rear hinge does not look straight...
door skews
paper skews
you think its springs and stuff...
just replace or straighten rear hinge...
on the lct right door...
blackcat4866
08-18-2018, 02:49 AM
which bizhub?
n25an
08-19-2018, 02:52 PM
bizhub c452
n25an
11-25-2018, 10:30 AM
also sometimes that guide section above tray 3 and 4... the plastic gets warped... or has issues... and needs to be replaced... had that happen to me once...
Hansoon
11-25-2018, 11:12 AM
........or one of the lift cables jumped from one of the pulleys. Happened to me twice.
Hans
allan
11-25-2018, 10:37 PM
Hans
Still happens even on the 8 series...
anzew
03-30-2020, 02:57 AM
Hi guys how do I stop this from happening? Every time the customer opens the tray, the paper will slam down and cause the cable jump out of the pulley.
rrrohan
03-30-2020, 08:22 AM
or the hooks on door that keep door closed are snapped
srvctec
03-30-2020, 10:48 PM
I've just been putting small strips of mylar on the pulleys to prevent it from happening. Done it numerous times over the years with no call backs related to that issue.
