View Full Version : Konica C364e lines through ADF (trailing edge of original)
jonbonse
08-21-2018, 03:49 PM
Hi All
I have Konica C364e that when copying through the ADF produces a line which turns out to be the trailing edge of the original showing up on the copy....Please see the pics...
Is there anything I can do to blank this?
On the Ricoh's, there used to be a user setting letting you erase by the mm....
copier tech
08-21-2018, 05:54 PM
Set up the DF correctly in CE mode & you wont get a line.
If in doubt consult the service manual.
jonbonse
08-21-2018, 06:11 PM
Is CE mode Konicas name for Service Mode?
copier tech
08-21-2018, 06:21 PM
Yes, so you clearly are not one!
jonbonse
08-21-2018, 06:36 PM
Not one what??? A service mode? 😏
Phil B.
08-21-2018, 07:29 PM
(C)ustomer (E)ngineer Mode
Phil B.
08-21-2018, 07:30 PM
NO clearly not a CE.
copier addict
As soon as you become a service mode let us know. Lol :cool:
jonbonse
08-21-2018, 07:35 PM
Hehe 😂
jonbonse
08-21-2018, 07:42 PM
Hehe 😂
anyways, I have found the info in the (S)ervice (M)anual so will see how I get on..😉
tsbservice
08-21-2018, 07:51 PM
Don't move the machine around pushing DF. It's not square to the main body thus you get the line.
Redo DF setup, like new out of a box or follow the correct procedures in SM to adjust DF.
jonbonse
08-21-2018, 07:56 PM
Thank you
Its an end of lease machine I bought and I’m guessing the delivery guy manouvered the machine with the DF..
copier addict
08-21-2018, 09:51 PM
Thank you
These DFs will go out of adjustment just by looking at them too hard. But running the adjustments in the (S)ervice (M)anual will fix it up.
floody
08-24-2018, 10:30 AM
looks me to the DF is not in line correctly, loosen the screws on the hinges and adjust the DF
