View Full Version : C552 turn of imaging unit warning?
mrfuser
08-22-2018, 04:00 AM
Ok we went into service mode and extra stop 0 c and told it no stop and told it not to remind consumables and yet it still pops up and fills entire user screen when idle. Any idea why?
Synthohol
08-22-2018, 04:04 AM
firmware up to date?
did you try to disable the warning AFTER it was already triggered?
i never had luck shutting down warnings after they were already on screen. only before.
copyman
08-22-2018, 12:40 PM
Agree with syn, if message was already on you cant turn it off unless you replace the unit
srvctec
08-22-2018, 02:47 PM
I also agree that if it's already tripped no way to make it go away. Also, make sure in service mode>System 2>Consumable Life Reminder is turned off. This is the one that makes the entire screen display the message vs. just a text above to the "Ready to copy." message, unless that's what you are referring to. If that's the case, I have turned this setting off after the counter was tripped and prevented the entire screen being blocked by the message by turning off the above setting.
Vikingrepairguy
08-22-2018, 03:53 PM
see if this helps at all
t85ster
08-25-2018, 09:59 PM
This doc from KonMin should help... for many older models...
copier tech
08-26-2018, 10:40 AM
Update the firmware, change DIP switches 50 & 51 as per bulletin reboot & the "replace IU" message will be gone it will be replaced the the L1/2/3/4 warnings but only from the "oil can" screen.
