View Full Version : Miscellaneous DR-012 Humidity problem
It is rainy season.
(maybe Humidity problem)
We are cleaning the DRUM(DR012!!!!) every day.
Is there a good way to use it?
DRUM, DEV, WIRE, BELT, BLADE, GRID replaced machines.
Pict : Test Pattern9
40494
Woxner
08-29-2018, 04:11 AM
make sure all your filters are clear so air flows. may need a dehumidifier. rains alot in florida but dont really have that problem.
All filters were in good condition. but I will check again! thanks
Ventilation equipment is attatched back side.
Room humidity is between 30% and 60%(rainy season). normally 30~40%.
Many places around me are complaining about the problem.
copier tech
08-29-2018, 09:00 AM
Are you using genuine toner?
Yep!
Toner, Drum, Developer, Blade, web, belt and etc
All parts are genuine.
Drum causes this problem.
some Drums were OK. but most of DR-012 is making trouble.
I can't replacing it everytime.
So I have to cleaning it.
thanks for your reply!
tsbservice
08-29-2018, 07:01 PM
Looks to me you answered your own question.
I would suspect some bad batch of drums. Can you claim those with the problem back to your KM distributor?
Toxic
08-29-2018, 08:21 PM
Strange situation...
Does it matter what is drum life when starts making this problems?
How do you clean drum and after cleaning it is ok?
First and last time i was cleaning drums every few days was few years ago when all get faulty batch od DU-102 drums.
Soon KM,relase firmware and modified cleaning blade...
But that was different problem,cleaning problem,not like this in your case.
blackcat4866
08-30-2018, 12:30 AM
Is there a time factor, like in the morning after turning down the air conditioner overnight? =^..^=
Yep. Faulty Drum Issue. KM knows this issue.
I exchanged drums several times.
Under 100,000p is free. but over 100,000p is not.
Sometimes new.
Most are between 100,000 ~ 300,000pages.
I used a dry towel or ethanol for cleaning.
After Cleaning is OK.
40533
before / after
I heard a few weeks, ago. that they are testing a new DR and Cleaning Unit(blade unit).
Depending on the DRUM condition, it can be several hours or days.
It occurs when the operation rate of the equipment is low.
However, it can not be used consistently every day.(weekend, holiday. etc...)
thx
