View Full Version : developer di550
anderson
09-05-2018, 02:13 PM
Hello everyone .could someone please let me know if there is any other developer of other equipment that I can replace in a di550, since it has been discontinued.
Phil B.
09-05-2018, 02:27 PM
you are asking for problems doing that.
anderson
09-05-2018, 02:37 PM
[QUOTE = Phil B.; 698734] você está pedindo problemas para fazer isso. [/ QUOTE]
Phil B.
I have some equipment and I can not find the developer for sale, so I thought I would replace it with another one, an idea would be to use 3 di211 developers on a di550
exCSER
09-05-2018, 04:33 PM
Precision Roller has it available on their website. Precisionroller.com
Good luck!
copyman
09-05-2018, 09:23 PM
Did you google it? I was curious because I bought it a few times over the last year so I did a google search and many places are still selling it. Worse case is there is probably an aftermarket developer "specific" for those models.
A lot of the toner is same or close but you just can't experiment. It could be a very costly experiment! If I was at a point to keep a machine alive because of discontinued dev or toner. I would at least try and find a dev & toner from around the same age. All developers have the weight on the bag / box so you could eyeball the weight needed or better yet weigh it. I would not take newer machs supplies and try them in older models!
Synthohol
09-05-2018, 10:08 PM
Konica Minolta DI450 Black Developer, Genuine (G7907) (https://www.precisionroller.com/developers-for-konica-minolta-di450/details_7183.html)
Amazon.com: KONICA MINOLTA OEM 502A DEVELOPER (BLACK) (502A, 89369121, 8936912) -: Office Products (https://www.amazon.com/KONICA-MINOLTA-DEVELOPER-89369121-8936912/dp/B00589V4QM)
For Konica Minolta Di550 Di470 Di450 Di 550 470 450 Developer 502a 8936-912 8936-9121 89369121 - Buy For Minolta Di550 Developer,For Minolta Di470 Developer,For Minolta Di450 Developer Product on Alibaba.com (https://www.alibaba.com/product-detail/For-Konica-Minolta-Di550-Di470-Di450_60724608767.html?spm=a2700.7724857.normalLis t.9.65a326d5v1oBvM)
Konica-Minolta 8936-912 502A OEM Developer - Newegg.com (https://www.newegg.com/Product/Product.aspx?Item=9SIA1E51762754&ignorebbr=1&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-Accessories+-+Printers%2FScanners%2FFaxes-_-9SIA1E51762754&gclid=EAIaIQobChMIuLzNgeKk3QIVjoWzCh0CPw_lEAkYAyAB EgJ8evD_BwE&gclsrc=aw.ds)
502a starter. i miss those days ;)
