View Full Version : Epson WF-R4640
Arkynsaw
09-05-2018, 05:21 PM
Having print quality issues , not getting good fill on the nozzle check and getting black streaks with kind of a swishy look , not consistent , like crud on the underside of the printhead . Tried cleaning the printhead thru the op panel like an end user , then tried putting a paper towel under the printhead with head cleaner on it and let it soak for a couple hours , then wiped with a dry Paper towel . Still no better . Does anyone have a service manual or any ideas how to proceed ? The printhead is buried and is fed from bags of ink on the side of the unit thru tubes , so I can not purge this unit as sometimes works . Thanks in advance , Ark .
Phil B.
09-05-2018, 06:20 PM
i have the service manual... give me your email addy.
one trick I have found... take a paper towel fold n cut to fit in the track where the printhead runs. Wet the towel with Simple Green Cleaner... push printhead over towel... now spray and blot up the docking station ( be sure to clean the wiper blade well ) ... let it sit for about 30 or so minutes ..remove towel and try a nozzle check. This has worked on every Epson... HP...Brother..and FP ink/heads.... so far about 30 machines...
Arkynsaw
09-06-2018, 10:08 PM
Thanks Phil B , I did receive the link and downloaded the file , will get a look see and try to reply here when I get to the end of it .
lokahi
07-28-2023, 06:21 AM
Aloha,
I have the same issue with my Epson Workforce Pro wf-r4640 printer that the above post was replying to. I would very much appreciate it if you could share the link to the service manual with me so I can hopefully take care of this problem.
My email is keaoku@hawaii.rr.com
Thanks,
Eric
dnpterry
09-15-2023, 04:45 PM
Hi Phil B Is there a video for this re the wf-r4640? Will another cleaner besides Simple Green work?
TYSM!
